PARAM, RBE2FREE
Bulk Data Entry Used to convert ERROR 725 into WARNING 825 when singular RBE2 elements are present in the model.
| Parameter | Values | Description |
| RBE2FREE | <YES, NO> | Modeling errors can result
in the creation of RBE2 elements with rigid body
rotations. This parameter can be used to convert ERROR 725 into
elements, with rotational rigid body modes in all three directions,
- To solve a problem with Lanczos or static analysis, AMSES can used first to determine which RBE2 degrees-of-freedom are AUTOSPC'ed. Single point constraints (SPC) can be added to manually constrain such degrees-of-freedom in subsequent static analysis or Lanczos eigenvalue analysis.
