PARAM, STRTHR
Bulk Data Entry Used to specify the von Mises stress threshold above which the stress results are output for a model.
| Parameter | Values | Description |
| STRTHR | <Real ≥ 0.0> Default = 0.0 |
This parameter can be used to specify the von Mises stress threshold above which the stress results are output for a model. |
- PARAM, STRTHR applies to all
static subcases defined within a model. The stress results for a particular
element are not output, ONLY if its von Mises stress value falls below
STRTHR for ALL static subcases.
For example, if the von Mises stress results for elements ID=1 and ID=2 fall below the threshold for subcase 1, but are above the threshold for subcase 2; then the stress results for both elements (ID=1 and ID=2) are output for both subcases.
- PARAM, STRTHR applies to stress results output in all active formats.
- PARAM, STRTHR is supported for static analysis only.
- If PARAM, STRTHR is defined in a model, then 1D element stresses are not output, regardless of their stress level or the specified threshold.
