Bulk Data Entry Controls the internal constraints of
PBARL and PBEAML properties during
optimization.
| Parameter |
Values |
Description |
| BARCON |
<REQUIRED or
EXTENDED> |
- REQUIRED (Default)
- A required set of constraints are applied. This option
prevents situations that are geometrically infeasible.
This option is usually sufficient (and is the default),
provided that positive lower bounds are specified on the
design variables corresponding to the bar
dimensions.
- EXTENDED
- Applies an extended set of constraints. This option also
enforces positive dimensions (constrains the various
dimensions of the properties to be greater than zero) in
addition to the set of constraints applied by the
REQUIRED option.
- REQUIRED is usually sufficient (and is the default),
provided that positive lower bounds are specified on the design variables
corresponding to the bar dimensions. However, if such positive lower bounds are
not set, the EXTENDED option can be used, which may introduce a
large number of constraints with minimal benefit.
- Example:
For
PBARL/
PBEAML
TYPE=
BOX), you have the following
constraint options:
- REQUIRED
- DIM1 > 2*DIM4 and DIM2 > 2*DIM3
- EXTENDED
- DIM3 > 0 and DIM4 > 0 (in addition to constraints defined by
REQUIRED)
