DRESP1 - Static Stress/Strain Item Codes for Composites
| Stress Item | Location | ASCII Code | Number Code1 |
| Normal - 1 | Default | S1 | 3 |
| Normal - 2 | S2 | 4 | |
| Shear - 12 | S12 | 5 | |
| Shear - 1Z | S1Z | 6 | |
| Shear - 2Z | S2Z | 7 | |
| Maj. Principal | SMAP | 9 | |
| Min. Principal | SMIP | 10 | |
| Normal - 1 | Top | S1-T | - |
| Normal - 2 | S2-T | - | |
| Shear - 12 | S12-T | - | |
| Shear - 17 | S17-T | - | |
| Shear - 27 | S27-T | - | |
| Maj. Principal | SMAP-T | - | |
| Min. Principal | SMIP-T | - | |
| Normal - 1 | Bottom | S1-B | - |
| Normal - 2 | S2-B | - | |
| Shear - 12 | S12-B | - | |
| Shear - 17 | S17-B | - | |
| Shear - 27 | S27-B | - | |
| Maj. Principal | SMAP-B | - | |
| Min. Principal | SMIP-B | - | |
| Normal - 1 | Both Top and Bottom | S1-O | - |
| Normal - 2 | S2-O | - | |
| Shear - 12 | S12-O | - | |
| Shear - 17 | S17-O | - | |
| Shear - 27 | S27-O | - | |
| Maj. Principal | SMAP-0 | - | |
| Min. Principal | SMIP-0 | - |
| Strain Item | Location | ASCII Code | Number Code 1 |
| Principal Angle | PSA | - | |
| Principle Angle | PSA-T | - | |
| Principle Angle | PSA-B | - | |
| Maj. Principal | SMAP-O | - | |
| Min. Principal | SMIP-O | - | |
| Principle Angle | PSA-O | - |
| Thermal Strain Item | Location | ASCII Code | Number Code 1 |
| Normal - 1 | Default | TS1 | - |
| Normal - 2 | TS2 | - | |
| Shear - 12 | TS12 | - | |
| Maj. Principal | TSMAP | - | |
| Min. Principal | TSMIP | - | |
| Normal - 1 | Top | TS1-T | - |
| Normal - 2 | TS2-T | - | |
| Shear - 12 | TS12-T | - | |
| Maj. Principal | TSMAP-T | - | |
| Min. Principal | TSMIP-T | - | |
| Normal - 1 | Bottom | TS1-B | - |
| Normal - 2 | TS2-B | - | |
| Shear - 12 | TS12-B | - | |
| Maj. Principal | TSMAP-B | - | |
| Min. Principal | TSMIP-B | - | |
| Normal - 1 | Both Top and Bottom | TS1-O | - |
| Normal - 2 | TS2-O | - | |
| Shear - 12 | TS12-O | - | |
| Maj. Principal | TSMAP-O | - | |
| Min. Principal | TSMIP-O | - |
| Mechanical Strain Item | Location | ASCII Code | Number Code 1 |
| Normal - 1 | Default | MS1 | - |
| Normal - 2 | MS2 | - | |
| Shear - 12 | MS12 | - | |
| Maj. Principal | MSMAP | - | |
| Min. Principal | MSMIP | - | |
| Normal - 1 | Top | MS1-T | - |
| Normal - 2 | MS2-T | - | |
| Shear - 12 | MS12-T | - | |
| Maj. Principal | MSMAP-T | - | |
| Min. Principal | MSMIP-T | - | |
| Normal - 1 | Bottom | MS1-B | - |
| Normal - 2 | MS2-B | - | |
| Shear - 12 | MS12-B | - | |
| Maj. Principal | MSMAP-B | - | |
| Min. Principal | MSMIP-B | - | |
| Normal - 1 | Both Top and Bottom | MS1-O | - |
| Normal - 2 | MS2-O | - | |
| Shear - 12 | MS12-O | - | |
| Maj. Principal | MSMAP-O | - | |
| Min. Principal | MSMIP-O | - |
