Edit Element Panel
Use the Edit Element panel to hand build, combine, split, or modify elements.
In the Edit Element subpanel you can stitch two unconnected meshes by adding elements between them, split elements at weld locations, and combine and split elements to fix connectivity in the transitional area between fine and coarse mesh areas.
Create Subpanel
Use the Create subpanel to create elements manually by selecting nodes. For example, you can use this subpanel to build elements in a situation where three elements are to be joined with two elements. You can create multiple plot elements by selecting by path from the node list selector. The element type is selected, followed by the selection of nodes to create the element. The element is automatically generated as soon as the required number of nodes for the chosen element type is selected. After at least two or more nodes are selected, click create to create whatever element type is appropriate for the number of nodes selected.
For example, while creating quads, you need to create one tria. You can leave the element type as quad, select three nodes, and then click the middle mouse button to complete the selection. A tria element is generated. Similarly, while creating a hexa element, you can create any lower element type without changing the element type to be created.
| Option | Action |
| node list | Select a group of nodes from which you wish to create an element. |
| plot, tria, quad, tetra, pyramid, penta, hex | Choose the type of element you wish to create. |
| auto order | Enables the mesher to
                                    automatically determine the node order. Clear this checkbox to
                                    manually select the nodes in the appropriate order.  This option may re-sequence the selected nodes to prevent the creation of inverted or folded elements.  |
| elem types = | Select an element type to create. |
Combine Subpanel
| Option | Action |
| elems | Select the elements you wish to combine. |
| combine to quad / combine to tria | Select the type of elements result from the combination. |
| tolerance = | Specify a planar tolerance angle. Elements deviating from a plane by this degree or greater will not be combined. |
| auto comb = | Specify the number of elements to automatically combine once selected. To disable auto-combine behavior, enter 0. |
Split Subpanel
Use the Split subpanel to split 1D and 2D elements, either singly or in a group. You must first select the elements to be split (or toggle to displayed elems to consider all elements in the display for splitting), then select the split-line points along which you wish to split the elements. To split an element, the split line must cross that element's boundary; where the split line crosses the element boundary determines how it will be split. If the split line crosses near a corner vertex, the split will be snapped to that node. If the split line crosses near the midpoint between two corners, a node will be added at the exact midpoint and the split will occur there.
| Option | Actions |
| displayed elems / elems / comps | Select which elements
                                    to split.
| Splitting line | Draw a line of one or more segments in the modeling window. Elements will be split along this line when you click split. Left-click to create a point along the line; right-click to remove the most recent point. There is no need to "finalize" the line series, it will persist until you click either split or delete line. |
| Consider 1Ds also | Split 1D elements, provided they fit the element selection criteria (visible, or selected, or part of a selected component). |
Cleanup Subpanel
| Option | Actions |
| displayed elems / elems | Choose between cleaning up all displayed elements, or only specific elements that you select. |
Command Buttons
| Button | Actions |
| create | Create the element |
| reject | Revert the most recent action, or clear the current selection. |
| combine | Combine the currently selected elements. This will only be necessary if you have disabled auto-combine, or wish to combine a number of elements that is less than the value of auto comb =. |
| split | Perform the split. Elements that the line passes through are split into two or more smaller elements. |
| delete line | Delete the current splitting line. |
| return | Exit the panel. |
Cleanup Secondary Panel Options
| Option | Actions |
| max angle, warpage, jacobian, skew, length | Select any combination
                                    of checks. Elements that you have selected are color coded
                                    according to how well they fit the checks that are selected.
| node (place node) | When this is active, left-click and drag an existing node to reposition it. The affected elements' color coding changes dynamically as you drag the node. Release the mouse button to set the node at its new location. |
| edge (swap edge) | When this is highlighted, click an edge to swap it between its possible locations. The number of legal positions for an edge depends on the type of elements that it lies between: For a pair of trias, there are two possible positions for their shared edge. For a pair of quads, there are three possible positions. For a quad and a tria, there are six possible positions. Each time you pick the edge, it switches to the next legal configuration. |
| smooth | Execute an automatic smoothing algorithm over all of the selected elements. The behavior of this process is affected by the autodecide, size corrected, shape corrected setting below. |
| autodecide, size corrected, shape corrected | Select the behavior of
                                    the smooth function.
| undo | Revert the most recent cleanup action, including the automated smooth process. |
| redo | Perform the most recently undone cleanup action. |
| abort | Discard all changes made to the mesh and returns to the cleanup subpanel. |
