Use the Desvar Link panel to link a design variable to other design
        variables.
Note: Only available in the OptiStruct solver interface.
Dlink Subpanel
                                | Option |
                                Action |
                                | dlink |
                                Enter a name (maximum of 8 characters). |
                                | dependent: designvar |
                                Select a dependent design variable. |
                                | independent: designvar |
                                Select the design variables for the given link. You may edit
                                    the linear factors (default is 1.0). |
Dlink2 Subpanel
                                | Option |
                                Action |
                                | dlink2 |
Command Buttons
                                | Button |
                                Action |
                                | create |
                                Create the design variable link. |
                                | update |
                                Update the design variable link. |
                                | review |
                                Review the design variable link. |
                                | return |
                                Exit the panel. |
