Dependency Panel
Use the Dependency panel to find nodes that have their degrees of freedom removed by a constraint or MPC (multiple point constraint) more than once. By identifying and correcting such dependencies prior to solving, solution errors can be avoided.
                            ![]() Figure 1. Before  |
                            ![]() Figure 2. After  |
Panel Options
| Option | Action |
| entity selector | Select the entities
                                    you wish to check for dependencies. Use the switch to change
                                    between components and elements.  When you select elems, click
                                        the switch to change the selection mode.
| dependency | Perform the check and highlight any nodes in the selected entities that have multiple constraints or MPC's. |
| face angle / individual selection |
