Admas Panel
Use the Admas panel to create and update masses applied to nodes. The Adams panel supports the /ADMAS Radioss and *ELEMENT_MASS LS-DYNA element.
Create Subpanel
- Radioss
 - All of the selection options (nodes, components, properties, materials, sets and blocks) are available. However, when selecting groups of entities, only entities of the same type can be selected. Regardless of type, a node set is always created from the selected entity, and the defined mass is always applied to this node set.
 - LS-DYNA
 - You can only select nodes, components, or sets. The corresponding *ELEMENT_MASS is created, depending on the entity type selected. You can select more than one node or component, but the selected entities must all be of the same type.
| Option | Action |
| attach node as a set | Place the selected entity in a set and define the mass for
                                    the entire set. Radioss: This checkbox is always selected because this option is required by the solver. LS-DYNA: When this checkbox is enabled, each selected entity is placed in a node/part set, and the mass value is associated with the set. Clearing this checkbox keeps the selected entities separate/ungrouped.  |
| mass= | Define the mass to be applied on the selected entities. How it is applied depends on mass type. |
| mass type | Radioss:
| visualization node | Select a node to display the mass handle in the modeling window. Radioss: Available when a set is created, regardless of the other options chosen. LS-DYNA: Available when a component or set is selected.  |
Update Subpanel
| Option | Action |
| mass update | Change the mass value and type of a selected mass element. |
| connectivity update | Update the entities on which the selected mass element is
                                    defined The choice for entity selection to update is limited to
                                    the type of entity that already exists in the selected
                                            element. LS-DYNA: If the selected element has just a node or a component and you add more than one entity of same type then the selected entities by default is converted to a set and is associated with mass.  |
| visualization node update | Update the visualization node associated with the selected mass element. |
Command Buttons
| Button | Action |
| create | Create the mass element. |
| create/edit | Create the mass element and open the card image, from which you can make additional card edits. |
| reject | Cancel the creation of mass elements. |
| return | Exit the panel. |
