Use the Assemblies panel to create and modify assemblies, which are collections of
        component and multibody collectors or other assemblies. This method of grouping component
        and multibody collectors is useful because once an assembly is created, it is possible to
        display components or multibodies by assembly, or to select entities by assembly rather than
        by component.
        Card Image Subpanel Options
                                | Option |
                                Action |
                                | assem name= |
                                Enter the name of the assembly, or click assem
                                        name= to select an existing assembly. |
                                | card image= |
                                Enter the name of the card image, or click card
                                        image= to select an existing card image. |
        Card Image Subpanel Command Buttons
                                | Button |
                                Action |
                                | Load |
                                Load the selected assembly and card image. |
                                | Load/Edit |
                                Load and edit the selected assembly and card image. |
                                | Edit |
                                Edit the selected assembly and card image. |
                                | Reset |
                                Reset the current field to its original value. |
                                | Reset All |
                                Reset all fields to their original values. |
        Create Subpanel Options
                                | Option |
                                Action |
                                | assem name= |
                                | card image= |
                                | comps |
                                Select the component(s) to include in the assembly. |
                                | assems |
                                Select previously defined assemblies to include in the
                                    assembly. |
                                | multibodies |
                                Select previously defined multibodies to include in the
                                    assembly. |
                                | color |
                                Select a color for the assembly |
        Create Subpanel Command Buttons
                                | Button |
                                Action |
                                | Create |
                                Create the assembly and card image. |
                                | Create/Edit |
                                Create and edit the assembly and card image. |
                                | Update |
                                Update the assembly and card image with changed
                                    information. |
                                | Review |
                                Review changes made to the assembly and card image. |
