Linear Solid Panel
Use the Linear Solid panel to create solid elements between two groups of plate elements.
Panel Options
| Option | Action |
| from: elems | Select the elements where you want the plot elements to begin. |
                                     Define the from line's alignment by clicking
                    N1 and selecting three alignment nodes on the first set
                of elements.
                                Note: This input is optional.
| to: elems | Select the elements where you want the plot elements to end. |
| to: alignment |
                                     Define the to line's alignment by clicking
                    N1 and selecting three alignment nodes on the second set
                of elements.
| distribute layers / specify layers | Choose between automatically distributing the generated layers, or specifying their locations. |
| density = | Specify the number of
                                    layers to be created between the two groups of
                                        elements. Note: Only available when using the distribute
                                        layers option.
| node list | Select the sequence of
                                    nodes that define the layers you want to create. The first node
                                    should be of the from: elements and the last node should be the
                                    corresponding node of the to: elements. Note: Only available when
                                        using the specify layers option.
| bias style | Choose between linear,
                                    exponential, or bellcurve bias. This affects the spacing of the
                                    elements created during the drag. Note: Only available when using
                                        the distribute layers option.
| bias intensity | Specify the strength
                                    of the biasing effect. A value of zero indicates no biasing at
                                        all. Note: Only available when using the distribute layers
                                        option.
Command Buttons
| Input | Action |
| solids | Generate the solid elements. |
| reject | Undo the most recent solid generation. |
| return | Exit the panel. |
