Radioss Panel
Use the Radioss panel to execute a Radioss run on your desktop from HyperMesh.
Panel Options
| Option | Action |
| input file: | Navigate to the desired input file. |
| export options | Select an export
                                    option before you execute a Radioss
                                        run.
| run options | Select a run option
                                    before you execute an Radioss
                                        run.
| memory options | Specify the memory
                                    limit, and decide whether or not to run an in-core or
                                    out-of-core solution depends. The memory default can be changed using the system setting (SYSSETTING) option OS_RAM. You can assign a different memory limit for an individual run by entering a value for memory in upper limit in Mb= or by defining the -len option in the run script.  |
| include connectors | Include predefined connectors in the output file. |
| options: | Specify any additional options to write to the solver. |
Command Buttons
| Button | Action |
| Save as | Choose the run location and provide the filename for the OptiStruct input file. |
| Radioss | Automatically perform
                                    the following procedures:
| HyperView | Launch a new session of HyperView and load the resulting .mvw file from the OptiStruct run. (Specifically this loads the .mvw file corresponding to the file name in the input file: field.) |
| view .out | View the .out file after a run has been submitted. |
