Use the Opti Control panel to define control parameters for an
        optimization.
Note: Only available in the OptiStruct solver interface.
        Panel Options
                                | Option |
                                Action |
                                | parameters |
                                Activate a parameter
                                    by enabling its corresponding checkbox. |
                                | MFD / SQP /
                                    DUAL |
                                Choose between Method
                                    of Feasible Directions, Sequential Quadratic Programming, or
                                    DUAL. |
Command Buttons
                                | Button |
                                Action |
                                | next |
                                Go to the next page of
                                    parameters. |
                                | prev |
                                Go back to the
                                    previous page of parameters. |
                                | card edit |
                                Edit the control
                                    card. |
                                | return |
                                Exit the
                                    panel. |
