Entity Sets Panel
Use the Entity Sets panel to create, update, and review named sets of entities.
You can create sets for nodes, elements, components, sets, properties, materials, assemblies, multibodies, ellipsoids, multibody joints, and multibody planes. Depending on the solver interface loaded, only the entities relevant to that solver are enabled. For example, after loading the Nastran solver interface you can only create/update node and element sets.
An entity set contains a specific grouping of nodes, elements, or components. The nodes, elements, or components cannot be combined in one entity set.
Panel Options
| Option | Action |
| name | Specify the name of an entity set to create, or select an existing entity set. Selection options only include sets of the correct entity type (node set, element set, and so on.) |
| card image | Select a card image to apply to the set. This field is optional, and requires a solver interface with a valid template. |
| set type | Select a set type.
| entity | Choose the entities to be added to the set.
 When creating a formula-based set, this selector changes to a switch that allows you to change the entity type, but not to select the entities themselves (since that is done via the formulae).  |
| formula | Create a set based on mathematical ranges, such as creating a set for nodes with IDs from 1 to 1000. |
| add by ids/ range / remove by ids/ range |
| entity selector | Select the type of entity that you wish to pick. |
| from | Specify an ID value for the start of the
                                    range. Note: Only available when add/delete by range is
                                    selected
| to | Specify an ID value for the end of the
                                    selected
| add | Add the chosen expression to the individual expression list. |
| individual expression | Display the expressions selected. |
| ... | View all of the expressions at once. This opens a new window that shows every expression currently defined for the formula. |
Command Buttons
| Button | Action |
| create | Create the set in the
                                    database.  When creating formula-based sets, you must click create before you can add expressions to the formula.  |
| update | Clear the set contents and replace them with the new selection. To add new entities to an existing set without clearing, review the entities in the set, then select the new entities to be added, and click update. |
| card edit | Open the Card Editor for the currently selected card image. |
| review | Review the contents of a set. For component (or props, mats, assemblies, multibodies, and so on) sets, the elements that belong to corresponding components in the set are highlighted on the screen. You can identify the components in the set as those that are checked in the list (access the list by clicking the entity type). |
| return | Exit the panel. |
