Axis Labels Panel
Use the Axis Labels panel to edit the axis label information of the current plot or selected attributes in a group of plots.
                            ![]() Figure 1. No Title or Labels Applied  |
                            ![]() Figure 2. X-Axis Title and Label Applied  |
                            ![]() Figure 3. X-Axis and Y-Axis Labels Applied  |
Panel Options
| Option | Action |
| plot= | Select a single plot to edit the axis label information. |
| plots | Select multiple plots to change the label characteristics. |
| xaxis title= | Specify the x axis title. |
| xaxis label= | Specify the x axis label information. |
| yaxis title= | Specify the y axis title. |
| yaxis label= | Specify the y axis label information. |
| color | Change the color of the title and labels. |
| font | Select a new font for the title and labels. |
Command Buttons
| Button | Action |
| update | Update the plots with the changed information. |
| return | Exit the panel. |
