Property Collectors Panel
Use the Property Collectors panel to create property collectors, which are used to assign physical properties to entities.
Create Subpanel
| Option | Action |
| prop name = | Specify a name for the new property collector. |
| color | Select a color for the entity. |
| type = | Select a property
                                    type.  Tip: Use this option to filter property types
                                        by element dimension or application.
| card image / no card image / same as |
                                     Select a card image.
| material = | Select an existing material to assign to the new property collector. |
| reject | Undo the most recent action. |
Update Subpanel
| Option | Action |
| props | Select the property collectors you wish to update. |
Assign Subpanel
| Option | Action |
| elems | Select the elements to which you wish to assign a property collector. |
| property = | Select an existing property collectors. If none display, you must first create some. |
Command Buttons
| Button | Action |
| create | Create the new property collector. |
| create/edit | Create the new property collector and open the Card Edit panel. |
| update | Change the selected property collectors to have the characteristics currently defined on the subpanel. |
| update/edit | Change the selected property collectors to have the characteristics currently defined on the subpanel, and open the Card Edit panel. |
| reset | Reset all of the fields on the subpanel to the selected collector's original characteristics. |
| assign | Assign the chosen property to the selected elements. |
| unassign | Remove all of the property assignments from the selected elements. |
| review | Select a property in the property = field, then click review to see its current characteristics. |
| reject | Undo the most recent assign action. |
