Plots Panel
Use the Plots panel to create and manage plot collectors.
                            ![]() Figure 1. Standard Plot  |
                            ![]() Figure 2. Dual Plot  |
Panel Options
| Option | Action |
| plot = | Specify a name for the plot collector. |
| like = | Click to select an existing plot whose default values you want to use for the new plot. |
| standard / real/imag / phase/mag | Select a method for
                                    creating plots.
 Note: After you create a real/imag or phase/mag plot, the
                                        standard selection is removed from the menu.
Command Buttons
| Button | Action |
| create plot | Create a new plot based on the current inputs. |
| select curves | Select the curves to
                                    display.  After you click return, the
                                        curves you selected are displayed in the plot.
![]() Figure 3.  |
| return | Exit the panel. |
