Use the By Width option in the Extended Entity Selection menu to select surfaces
        based on their width.
        By Example Subpanel
            Use the By Example subpanel to select a sample surface and find the surfaces in your
                model with similar widths.
                                | Option |
                                Action |
                                | surf |
                                Select a sample surface. |
                                | closed loops only |
                                    Systematically disregard surfaces that do not form a
                    closed loop.
                                | has free edges |
                                    Surfaces must have at least one free edge to be
                    selected.
        By Value Subpanel
            Use the By Value subpanel to specify a range of values for width and find the
                surfaces that match this range, while taking into account any filtering options that
                are enabled.
                                | Option |
                                Action |
                                | min width |
                                Enter the minimum width of the surface to find. |
                                | max width |
                                Enter the maximum width of the surface to find. |
                                | has free edges |
                    selected.
        Command Buttons
                                | Button |
                                Action |
                                | select |
                                Select the surfaces highlighted. |
                                | reject |
                                Reject the current selections. |
                                | return |
                                Exit the panel. |
