Use the Discrete dvs panel to define a discrete design variable value table for use
        in size or shape optimization, which maybe be referenced in the ddval = field on the Size,
        Gauge or Shape panels..
Note: Only available in the OptiStruct solver interface.
Panel Options
                                | Option |
                                Action |
                                | name |
                                Enter a name (maximum of 8 characters). |
                                | individual values |
                                Enter the individual values. |
                                | value range: from |
                                Enter the starting
                                    number for the value range. |
                                | value range: to |
                                Enter the ending
                                | value range: increment |
                                Enter an increment for
                                    values within the range. |
        Command Buttons
                                | Button |
                                Action |
                                | create |
                                Create the design variable. |
                                | review |
                                Review the design variable. |
                                | return |
                                Exit the panel. |
