Skin Panel
Use the Skin panel to create a skin surface and/or mesh from a set of lines.
Panel Options
| Option | Action |
| line list | Select the lines that you wish to create a skin surface between. The lines do not need to be contiguous, but should not be collinear. |
| mesh options switch |
| auto reverse / no reverse |
                                     When elements are generated, the edges used to create
                this mesh can be ordered in different directions, causing HyperMesh to create a mesh that crosses itself, resembling a bow tie. The order of the
                edges is determined by the order in which the nodes were selected or the direction
                of the selected line(s).
Command Buttons
| Button | Action |
| create | A surface and/or mesh
                                    is created that interpolates a set of lines in the order they
                                    are selected. At least two lines must be selected. Select
                                        auto reverse to insure the same
                                    direction for all lines.  The lines used to create the skin surface and/or mesh are automatically smoothed before it is created. As a result, the surface and/or mesh created has a single face.  |
| reject | Undo the most recent skin creation. |
| return | Exit the panel. |
