Border Panel
Use the Border panel to edit the appearance of the border that designates the window around an xy plot.
Panel Options
| Option | Action |
| plot= | Select the plot in which you want to edit the border information. |
| border margin= | Specify the width of the margins around the plot. |
| thin border / thick border | Apply a thin or thick line for the border. |
| border color | Select a border color. |
| border on | Display the border. Clear this checkbox to turn the border off.  |
| plots | Select the plot(s) to update. |
Command Buttons
| Button | Action |
| update | Update the plots with the changed information. |
| return | Exit the panel. |
