Use the ALE Setup panel to create and modify input data pertaining to the
        Arbitrary-Lagrangian-Eulerian.
Important: Only available in the LS-DYNA solver interface.
        Create Subpanel
            Use the Create subpanel to create ALE groups.
                                | Option |
                                Action |
                                | name |
                                Specify a name for the ALE card. |
                                | type |
                                Specify a type for the ALE card.
                                            - Type (HyperMesh Card
                                                Image)
                                            - LS-DYNA Keyword
                                            - ConstdLagSolid
                                            - *CONSTRAINED_LAGRANGIAN_IN_SOLID
                                            - InitialGasMix
                                            - *INITIAL_GAS_MIXTURE
                                            - InitialVoid
                                            - *INITIAL_VOID_PSID
                                            - DatabaseFsi
                                            - *DATABASE_FSI
                                            - DatabaseFsiSensor
                                            - *DATABASE_FSI_SENSOR
                                            - BoundAmbEos
                                            - *BOUNDARY_AMBIENT_EOS
                                            - InitVolFractGeo
                                            - *INITIAL_VOLUME_FRACTION_GEOMETRY
                                            - InitialALEMapping
                                            - *INITIAL_ALE_MAPPING
Additional cards related to ALE modeling:
                                        - *SECTION_POINT_SOURCE
                                            (collector/property panel)
                                            (*Element_Solid card image)
                                | color |
                                Select a color for the ALE group. |
        Add/Update Subpanel
            Use the Add/Update subpanel to link entities such as components or a set to the ALE
                cards created in the Create subpanel.
                                | Option |
                                Action |
                                | name |
                                | options |
                                Use the entity selector to select entities to link to the ALE
                                    card. |
        Command Buttons
                                | Button |
                                Action |
                                | create |
                                Create the ALE card. |
                                | update |
                                Update the selected card with the new information. |
                                | create/edit |
                                Create the ALE card and immediately open the Card Editor with
                                    the ALE card loaded. |
                                | review |
                                Highlight the selected mass element. |
                                | edit |
                                Open the Card Editor with the current ALE card
                                    loaded. |
                                | update color |
                                Update the ALE card color with the newly selected
                                    color. |
                                | return |
                                Exit the panel. |
