Deformed Panel
Use the Deformed (deformed shape) panel to plot displacement analysis results.
Use this Deformed panel to see the motion of your structure after analysis. You can display both the original structure and the deformed shape to see the total amount of movement, or view the deformed shape by itself. You can also create an animation sequence of the structure's movement that shows the motion of the structure in a series of frames, based on what the analysis code has predicted the structure will do.
This function requires that you use a HyperMesh results file containing displacement data.
Panel Options
| Option | Action |
| simulation | Select the simulation that should be used to calculate the deformed shape of the structure. |
| data type | Select the data type
                                    structure.  If your graphics device is not capable of generating stress contour animation sequences, data type = is ignored. If stress contour animation is not desired, set the data type to none (blank). This allows HyperMesh to bypass contour calculations when generating the animation sequences.  |
| title | Enter a title for the plot. |
| model units / scale factor | Select the type of results multiplication to be performed. |
| undef color | Select a color for the undeformed structure. |
| deform color | Select a color for the deformed structure. |
| color options selections | Select a method of
                                    coloring the undeformed structure.
| frames | Define the number of frames to be used in the animation sequence. |
Command Buttons
| Button | Action |
| prev | Move the simulation or data type to the previous simulation or data type. |
| next | Move the simulation or data type to the next simulation or data type. |
| deform | Plot the deformed structure. |
| linear | Plot a deformation from a linear results file. |
| modal | Animate the structure using modal results. Opens the Animation secondary panel. |
| reference | Set the reference frame for animation. Select the three nodes that define the coordinate system to be used as a reference point. |
| return | Exit the panel. |
