Objective Panel
Use the Objective panel to define the objective function for an optimization problem.
Panel Options
| Option | Action |
| min / max / minmax / maxmin | Choose an objective type. |
| response = | Click this button to
                                    select an existing response. Note: Only available for min or max
                                        objectives.
| dobjrefs / dsysid |
 Note: Only available for minmax or maxmin objectives.
Command Buttons
| Button | Action |
| create | Create the new objective entity. |
| update | Update the selected objective entity. |
| review | Populate the fields
                                    with data:
| return | Exit the panel. |
