Shrink Wrap Panel
Use the Shrink Wrap panel to generate an enclosed volume or solid mesh, and is typically used to approximate and simplify an existing model.
- Loose Shrink Wrap
 - Generate a loose-fitting shrink wrap mesh that generally conforms to the model.
 - Tight Shrink Wrap
 - Generate a tight-fitting mesh that adheres closely to the underlying model, capturing as many features as possible.
                            ![]() Figure 1. Coarse STL Mesh Used as Input  |
                            ![]() Figure 2. Shell Mesh Wrapped Around the Original STL Mesh  |
Panel Options
| Option | Action |
| entity selector | Select entities to wrap. |
| features | Select feature lines
                                    on the model that must be retained. When meshed, elements will
                                    not cross over these lines.![]() Figure 3.  |
| tight wrap / loose wrap |
 Note: Not available when wrapping nodes or points.
| patch holes | If your model contains
                                    holes that you wish the shrink wrap to cover over as if they did
                                    not exist, enable the patch holes checkbox, and enter the
                                    sub-options accordingly.
                                    points.
| element size = | Specify the target
                                    element size for the shrink wrap mesh.  Note: Actual
                                        element size will vary depending on the model's features in
                                        order to improve mesh quality.
| generate solid mesh | Create the shrink wrap as a solid mesh rather than a shell mesh. This results in a mesh with no void space inside, rather than a hollow "bag" of mesh around the geometry. |
| mesh orientation: global system /local system | Choose whether to
                                    orient the mesh according to the global coordinate system, or a
                                    local one. This can strongly affect how the mesh follows the
                                    underlying geometry.![]() Figure 6. Shrink Wrap Output Using Global System . The mesh pattern runs diagonally across the pipes in the foreground. ![]() Figure 7. Shrink Wrap Output Using Local System. The mesh pattern is well aligned with the pipes in the foreground.  |
Command Buttons
| Button | Action |
| mesh | Create the new shrink wrap mesh according to the input values. |
| reject | Undo the most recent shrink wrap mesh creation. |
| features | Open the Features panel, where you can define feature lines in the model that should be preserved during the meshing process. |
| return | Exit the panel. |
