Beamsection Collectors Panel
Use the Beamsection Collectors panel to create and update beamsection collectors.
Create Subpanel
| Option | Action |
| beamsectcol name = | Specify the name of the beamsection collector. |
| color | Select a color for the entity. |
| card image |
                                     Select a card image.
Update Subpanel
| Option | Action |
| beamsectcol | Select the name of the beamsection collector to update. |
| card image |
Command Buttons
| Option | Action |
| create | Create a new beamsection collector. |
| create/edit | Create a new beamsection collector and open the relevant card image for editing. |
| update | Update the beamsection collectors with the changed information. |
| update/edit | Change the card image and edit specific details as if you were creating a new BeamSection collector. |
| reset | Revert all actions. |
| return | Exit the panel. |
