Use the Rigid Walls panel to create and update rigid walls.
            Location: Analysis page or Analysis page > Safety module
Rigid walls are used to define a contact or sliding rigid wall in an analysis code. In all solver
                interfaces except for LS-DYNA, rigid walls are created as
                group entities with configuration 5. In the LS-DYNA solver
                interface, rigid walls are created as rigid wall entities.
You can define the nodes included in a rigid wall using one of the four methods.
                        - nodes
                        - Create a secondary node for each node included in the rigid wall.
                        - components
                        - Provide a list of components. In this case, the analysis code is
                            provided with a list of component IDs.
                        - sets
                        - Select one or more previously defined entity sets. In this case, the
                            analysis code is provided with a list of the entity set IDs.
                        - all
                        - Include all the nodes in the model. If you select all, the keyword ALL
                            is used.
You can also select one or more previously defined entity sets. In this case,
                the analysis code is provided with a list of the entity set IDs.
The Rigid Walls panel displays fields for dictionaries or card images depending on the type of
                solver template that is referenced. If a card image template
                is loaded, or no template is loaded, the panel displays card image related fields. If a dictionary template is loaded,
                the panel displays dictionary related fields. Card image and dictionary entry fields
                are used in the same way except that when a card image
                solver is being used and edit is selected, the card image is
                displayed in a new area of the screen. For dictionary solvers, the data is shown in
                the existing menu area.
This function requires a template file.
Create Subpanel
                                | Option |
                                Action |
                                | name = |
                                Specify a name for the
                                    rigid wall that you wish to create. |
                                | type = |
                                Select a rigid wall
                                    type. |
                                | creation
                                    method |
                                    Select a  card image.
                        - card image
                        - Select a card image.
                        - no card image
                        - Do not use a card image.
                        - same as
                        - Select a collector that already uses the desired card image.
                                | rgdwall color |
                                Select a color for the entity. |
                                | size = |
                                Specify a size for the
                                    new rigid wall. |
Update Subpanel
                                | Option |
                                Action |
                                | name = |
                                Click to select an
                                    existing rigid wall. |
                                | type = |
                                Select a rigid wall
                                    type. |
                                | rgdwall color |
Geom Subpanel
                                | Option |
                                Action |
                                | name = |
                                Click to select an
                                | shape: |
                                Select the desired
                                    shape. |
                                | base node |
                                Select the base node
                                    for the rigid wall. Click edit to
                                    directly change the node's coordinates. |
                                | normal vector: |
                                Choose a method for
                                    defining the rigid wall's normal vector.
                                            - vectors
                                            - Use a standard plane and vector selector to define
                                                the vector via nodes or axes.
                                            - components
                                            - Manually specify the X, Y, Z components of the
                                                vector.
                                            - systemid
                                            - Define the vector by means of selecting a local
                                                system.
                                | shape: |
                                Define the geometric information.
                                            - finite plane
                                            - Define a finite plane using the selector to choose
                                                either the corner or dist/axis creation method.
                                                  - Use the corner method by selecting two
                                                  nodes.
                                                  - Use the dist/axis method using the vector
                                                  selector to specify the local x axis of the plane,
                                                  then specify the lengths of the local x and y
                                                  directions of the plane.
                                            - finite prism
                                            - Define a finite prism using the selector to choose
                                                  nodes.
                                                  selector to specify the local x axis of the prism,
                                                  then enter the lengths of the local x, y, and z
                                                  directions of the prism.
                                            - cylinder
                                            - Define a cylinder using the selector to choose
                                                either the node or radius creation method.
                                                  - Use the node method to select a node that
                                                  describes the radius of the cylinder.
                                                  - Use the radius method to enter the desired
                                                  - Specify the desired length of the cylinder. If
                                                  the length of a cylinder is zero, it is assumed to
                                                  be infinite.
                                            - sphere
                                            - Define a sphere using the selector to choose either
                                                  describes the radius of the sphere.
                                            - madymo plane or ellipse
                                            - Define a coupled MADYMO
                                                plane or ellipse, choose either to enter the ID of
                                                the plane or ellipse in the MADYMO input deck.
                                            - parallel
                                            - Specify two nodes as corner nodes of the parallel
                                                shape.
                                | shape:
                                    infinite/finite |
                                If plane or prism is
                                    selected for the shape, select infinite or finite. To describe
                                    an infinite plane or prism, no additional input is needed,
                                    additional details for a finite plane are described for
                                    shape. |
Add Subpanel
                                | Option |
                                Action |
                                | name = |
                                    rigid wall. |
                                | secondary: |
                                Select the secondary
                                        entities.
                                            - nodes
                                                rigid wall.
                                            - components
                                                analysis code is provided with a list of component
                                                IDs.
                                            - sets
                                                In this case, the analysis code is provided with a
                                            - all
                                                all, the keyword ALL is used.
Motion Subpanel
                                | Option |
                                Action |
                                | name = |
                                    rigid wall to which you want to add a motion
                                    description. |
                                | motion switch |
                                Choose between vectors
                                    and components to define the direction and magnitude of the
                                        motion.
                                            - vectors
                                            - Specify a value in the magnitude= field, then use
                                                the standard plane and vector selector to define the
                                                direction.
                                            - components
                                            - Specify the x,y,z values of the components.
                                | type of
                                    motion: |
                                Select the type of
                                    motion. |
Card Subpanel
                                | Option |
                                Action |
                                | name = |
                                Specify the name of
                                    the rigid wall. |
                                | card image = |
                                Specify the name of
                                    the rigid wall, its card image or
                                    dictionary displays in this field. Click
                                        edit to open the card image in edit
                                    mode, allowing you to modify the values in the card image or dictionary. |
Command Buttons
                                | Button |
                                Action |
                                | create |
                                Create the new rigid
                                    wall. |
                                | create/edit |
                                    wall and open its card image in edit
                                    mode. |
                                | update type |
                                Update the rigid wall
                                    type. |
                                | reject type |
                                Undo the most recent
                                    update to the rigid wall type. |
                                | update color |
                                Update the rigid
                                    wall's color, leaving all other traits the same. |
                                | review |
                                | update |
                                Update the rigid
                                    wall's geometry, nodes, or motion. |
                                | add |
                                Add the selected nodes
                                    to the rigid wall. |
                                | load |
                                Load the specified
                                        card image. |
                                | load/edit |
                                Load the specified
                                        card image and open it in edit
                                    mode. |
                                | edit |
                                Edit the specified
                                        card image. |
                                | reset |
                                Reset the specified
                                        card image, undoing any edits made
                                    to it. |
                                | reset all |
                                Reset all card images, undoing any edits made to
                                    them. |
                                | return |
                                Exit the
                                    panel. |
