By Window
Use the By Window option in the Extended Entity Selection menu to create a window that can be used to select entities on your model.
Figure 1. Window Selection
Panel Options
| Option | Action |
| points | Draw a window by selecting points in the modeling window. |
| interior | Select all entities within the window.![]() Figure 2. Interior Window Selection  |
| exterior | Select all entities outside the window.![]() Figure 3. Exterior Window Selection  |
| visible only | When disabled, only the visible elements inside of the
                                    selection window are taken into account. Visible means that the
                                    element centroid is visible (for solids at least one faces
                                        centroid). Select this checkbox to take into account all of the elements inside of the selection window.  |
Command Buttons
| Button | Action |
| select entities | Select the entities shown in the modeling window. |
| reject entities | Reject the selection. |
| delete window | Delete the current window. |
| return | Exit the panel. |
