System Collectors Panel
Use the Systems Collectors panel to create and update system collectors.
System collectors contain coordinate systems, which can then be applied to different components of a model.
Create Subpanel
| Option | Action |
| systcol name | Specify a name for the system collector. |
| color | Select a color for the entity. |
| card image |
                                     Select a card image.
Update Subpanel
| Option | Action |
| systcol | Select the system collector to update. |
| card image |
Command Buttons
| Button | Action |
| create | Create the system collector. |
| update | Change the card image of the selected cards. |
| update/edit | Change the card image and edit the specific details as if you were creating a new system collector. |
| return | Exit the panel. |
