Composite Shuffle Panel
Use the Composite Shuffle panel to define manufacturing constraints for composite shuffling optimization.
Location: Analysis page > Optimization panel ( OptiStruct user profile)
Create Subpanel
| Option | Action |
| dshuffle | Specify a name for the manufacturing constraint. |
| type |
                                     Select the type of manufacturing constraint to
                    create.
                                Note: PCOMP(G) covers both PCOMP and PCOMPG.
| entity selector | Select laminates or properties. |
Update Subpanel
| Option | Action |
| dshuffle | Enter the name of an existing constraint in the text area, or double-click to select an existing constraint. |
| type |
                    create.
Parameters Subpanel
| Option | Action |
| pairing constraint | Choose a pairing option. |
| successive plies: number of constraints | Number of constraints to apply to successive plies (MAXSUCC). |
| core: number of plies | Number of plies making up the laminate core (CORE). |
| cover: number of plies | Number of plies making up the laminate cover (COVER). |
Edit Card Image Subpanel
| Option | Action |
| MAXSUCC | Apply maximum number of successive plies constraints. |
| CORE | Apply a ply sequence for the core layer. |
| COVER | Apply a ply sequence for the cover layer. |
Command Buttons
| Button | Action |
| create | Create new manufacturing constraint. |
| edit | Open the specified constraint's card image, allowing you to alter its ply-related characteristics. |
| reject | Revert the creation of a constraint. |
| return | Exit the panel. |
| review | Highlight the specified constraint, and display its current characteristics in the input fields. |
| update | Update the selected constraint's characteristics or parameters to match your inputs. |
