| response type
                                    switch |
                                Select the response
                                        type. Note: Available when response type is selected.
                                            - mass, massfrac, volume, volumefrac, cog, inertia,
                                                compliance or beadfrac
                                            - Choose either total or by entity (or, where
                                                available, sum or combined).
                                            - For by entity, sum or combined select the desired
                                                entities.
                                            - static displacement
                                            - Use the nodes selector to select the desired
                                                nodes.
                                            - Enable the numbers checkbox
                                                to display the IDs of the selected nodes.
                                            - Select the degree-of-freedom for the response
                                                definition, or choose total disp or total
                                                rotation.
                                            - frequency, buckling
                                            - Specify the number of the mode for the response
                                                definition.
                                            - static stress, static strain, static force
                                            - Select the desired entities (elems, comps or props)
                                                to include in the response definition.
                                            - When elements are selected, enable the
                                                  numbers checkbox to display
                                                the IDs of the selected elements.
                                            - When comps or props are selected, under the
                                                excluding: heading choose individual elements to
                                                exclude from the response definition.
                                            - Depending on the nature of the response type and the
                                                elements, components or properties selected,
                                                additional arguments need to be defined indicating
                                                the type (von mises, normal, and so on) and location
                                                (z1, point 1, end A, and so on) of the
                                                response.
                                            - composite stress, composite strain, composite
                                                failure
                                            - Select the desired entities (elems or comps) to
                                            - When comps are selected, under the excluding:
                                                heading choose individual elements to exclude from
                                                selected, additional arguments need to be defined
                                                (normal 1, hill, and so on).
                                            - Choose from all plies, ply number =, and global ply
                                                number = (for PCOMPG property).
                                            - If ply number = or global ply number = is selected,
                                                specify the ply number for the response
                                                definition.
                                            - frf displacement, frf velocity, frf
                                                acceleration
                                                nodes.
                                                definition.
                                            - Choose from real, imaginary, phase and
                                                magnitude.
                                            - Choose from all freq, freq =, sum, avg, ssq, rss,
                                                max, min, avgabs, maxabs, minabs, and sumabs.
                                            - If freq = is selected, specify the desired
                                                frequency.
                                            - frf stress, frf strain, frf force
                                                response.
                                                magnitude.
                                                frequency.
                                            - function
                                            - Choose from dequation =, sum, avg, ssq, rss, max,
                                            - If dequation = is selected, click it and select the
                                                dequation definition to be used.
                                            - Click edit and enable the
                                                checkboxes of the variable(s) to use in the
                                                  function.
Note: RESPONSES and
                                                  RESPONSES_BY_LOADSTEP cannot be used in the same
                                                  function response.
                                            - Specify the number of each enabled variable type
                                                that will be referenced in the function
                                                  response.
Note: If a dequation is used
                                                  in the definition of a function response the order
                                                  of the variables on the left-hand side of the
                                                  dequation definition must match the sequence in
                                                  which they are listed on the DRESP2 card image,
                                                  that is, any TABLE_ENTRIES references must come
                                                  before RESPONSES references.
                                            - Select the variables by clicking the relevant yellow
                                                buttons that appear in the card image.
                                            - weighted comp
                                            - Use the loadsteps selector to select and weight the
                                                loadsteps to be used in the weighted comp
                                                response.
                                            - weighted freq
                                            - Select and weight the mode numbers to be used in the
                                                weighted freq response.
                                            - compliance index
                                                loadsteps to be used in the compliance index
                                                response.
                                                compliance index response.
                                            - If desired, toggle autonorm to norm = and enter the
                                                normalization factor.
