poIRenderOptions GetContourLightingEnabled
Gets the lighting state when a contour is applied.
poIRenderOptions_handle GetContourLightingEnabled
HyperView Tcl Query
This command retrieves the lighting state when a contour is applied.
Note: When contour lighting is disabled, the colors will not change when the display is rotated, therefore it may be easier to match the displayed colors with the legend.
Returns true if lighting is enabled, otherwise false.
