poIRenderOptions SetUndeformedUserColor
Sets the color for undeformed shape.
poIRenderOptions_handle SetUndeformedUserColor color
HyperView Tcl Modify
This command sets the color for undeformed shape.
Note: This option is valid only if a tracking system had been defined.
color
Set the color value using the RGB format (for example, 255 255 255).
Returns 0 if successful, otherwise an error code.
