poIRenderOptions SetPreloadDataEnabled
Sets the PreLoad Simulation Data state.
poIRenderOptions_handle SetPreloadDataEnabled state
HyperView Tcl Modify
This command sets the PreLoad Simulation Data state.
state
Set to true to load data first, then begin animation. Set to false to animate while loading data.
Returns 0 if successful, otherwise an error code.
