poIRenderOptions GetStereoPerspectiveAngle
Gets the perspective field of view angle when the stereoscopic display is enabled.
poIRenderOptions_handle GetStereoPerspectiveAngle
HyperView Tcl Query
This command returns the perspective field of view angle when the stereoscopic display is enabled.
To get the current stereoscopic perspective angle:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetRenderOptionsHandle render_options
render_options GetStereoPerspectiveMode
hwi CloseStack
Returns a value of "3" if the handle is invalid.
