poIRenderOptions SetAxisColor
Sets the color for the global axis.
poIRenderOptions_handle SetAxisColor axis color
HyperView Tcl Modify
This command sets the color for the global axis.
axis
Set to x, y, or z (also X, Y, Z or 1, 2, 3).
color
Set the value using the RGB format (for example, 255 255 255).
Returns 0 if successful, otherwise an error code.
