poIRenderOptions SetAllFeaturesMode (deprecated)
Sets the global flag controlling the display of non-visible geometry using feature lines.
Important: This command is deprecated and has been replaced with poIPost SetMeshMode.
poIRenderOptions_handle SetAllFeaturesMode true
HyperView Tcl Modify
This command sets the global flag controlling the display of non-visible geometry using feature lines.
true
For showing non-visible geometry using features lines.
Returns 0 if successful, otherwise an error code.
