poIRenderOptions SetContourLightingEnabled
Sets the lighting state when a contour is applied.
poIRenderOptions_handle SetContourLightingEnabled state
HyperView Tcl Modify
This command sets the lighting state when a contour is applied.
Note: When contour lighting is disabled, the colors will not change when the display is rotated, therefore it may be easier to match the displayed colors with the legend.
state
Set to true to enable lighting, or false to disable it.
Returns 0 if successful, otherwise an error code.
