poIRenderOptions SetCollectorTransparentMode
Sets the selection highlighting mode to transparent highlighting.
poIRenderOptions_handle SetCollectorTransparentMode true
HyperView Tcl Modify
This command sets the highlighting mode that will be in HyperWorks to transparent (true) or default (false). It corresponds to the graphical user interface option Preferences > Performance > Display > Transparent highlighting.
Note: It is recommended that this command only be used in HyperWorks and not in HyperWorks Desktop.
true
Set the highlighting to transparent.
Returns 0 if successful, otherwise an error code.
