poIRenderOptions SetLightPosition
Sets the light position.
poIRenderOptions_handle SetLightPosition position
HyperView Tcl Modify
This command sets the light position.
position
Set to two integer values, "x y", separated by a space. These two values range between -10 and 10.
Returns 0 if successful, otherwise an error code.
