poIRenderOptions SetStereoPerspectiveAngle
Sets the perspective field of view angle when the stereoscopic display is enabled.
poIRenderOptions_handle SetStereoPerspectiveAngle arg1
HyperView Tcl Modify
This command sets the perspective field of view angle when the stereoscopic display is enabled.
arg1
The field of view angle in degrees. The valid range is from 5 to 45.
To get the current stereoscopic perspective angle:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetRenderOptionsHandle render_options
render_options SetStereoPerspectiveAngle 30
hwi CloseStack
Returns a value of "3" if the handle is invalid.
