poIRenderOptions SetGradientType
Sets the gradient background layout.
poIRenderOptions_handle SetGradientType type
HyperView Tcl Modify
This command sets the gradient background layout (for example: vertical, diagonal1, etc.).
type
The name of the gradient type.
To set the gradient background layout to diagonal1.
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetRenderOptionsHandle render_options
render_options SetGradientType diagonal1
hwi CloseStack
None.
