poIRenderOptions SetMeshDetails
Sets the current value of the mesh detail slider.
poIRenderOptions_handle SetMeshDetails value
HyperView Tcl Modify
This command sets the value of the mesh detail slider (1 to 100). A lower value means that mesh lines are less likely to be displayed for fine meshes, and vice versa. A value of 100 means mesh lines are always shown, regardless of how fine the meshes are.
value
The mesh detail slider value (1 to 100).
To set the value of the mesh detail slider:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetRenderOptionsHandle render_options
render_options SetMeshDetails Value
hwi CloseStack
None.
