poIRenderOptions SetCollectorColor
Sets the selection highlighting color.
poIRenderOptions_handle SetCollectorColor color
HyperView Tcl Modify
This command sets the highlighting color that will be used for entity selection in HyperWorks. It corresponds to the graphical user interface option Preferences > Appearance > Selection Color.
Note: It is recommended that this command only be used in HyperWorks and not in HyperWorks Desktop.
color
Set the color using the RGB format (for example, 255 255 255).
Returns 0 if successful, otherwise an error code.
