poIRenderOptions GetStereo
Returns whether or not the stereoscopic display is enabled.
poIRenderOptions_handle GetStereo
HyperView Tcl Query
This command returns true if the stereoscopic (3D) display is enabled, or false if it is disabled.
To get the current stereoscopic display setting:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetRenderOptionsHandle render_options
render_options GetStereo
hwi CloseStack
Returns a value of "3" if the handle is invalid.
