exit
This command closes the application.
Inline mode usage
exit -h
Displays the help file that summarizes the parameters for this command.
exit
Closes the application.
When this command is issued, a dialog will require a confirmation from the user to exit newFASANT. If a project is already opened, it will give the possibility to save the project before exiting.
Figure 1. Dialog asking to save changes to the current project
