rhomboid
This command draws a rhomboid in the geometry.
Inline mode usage
rhomboid -h
Displays the help file that summarizes the parameters for this command.
rhomboid –n <name> -p <x1> <y1> <z1> <x2> <y2> <x3> <y3>
Draws a rhomboid in the geometry given three of its corner points are defined by the user.
Interactive mode usage
Invocation
rhomboid
  • First point.
  • Second point.
  • Third point.
The fourth point of the rhomboid will be calculated by adding the difference between the second point and the first point to the third point.
> rhomboid
First point [x y z]: 1 1 0
Second point [x y]: 3 2
Third point [x y]: 2 5
Result
Figure 1. Resulting rhomboid
