scale1D
This command scales only the specified dimension (X, Y, Z) of an object or objects by the factor specified by the user.
Inline mode usage
- scale1D -h
- Displays the help file that summarizes the parameters for this command.
- scale1D –all –p <scaleFactor>
- Scales all objects with a scale factor.
- scale1D <name> –p <scaleFactor>
- Scales one selected object with a scale factor.
- scale1D –nolocal -all –p <scaleFactor>
- Scales all objects with a scale factor, ignoring the reference plane to apply it.
- scale1D –nolocal <name> –p <scaleFactor>
- Scales one selected object with a scale factor, ignoring the reference plane to apply it.
Interactive mode usage
- Invocation
- scale1D or scale1D -all
- Parameters
- Objects to scale (when not using the all modifier). The objects can be selected by left-clicking on them in the geometry view (hold Ctrl for multiple selection) or by left-clicking on them in the tree view.
- Coordinate. The dimension to be scaled. Only one of the values "x", "y" or "z" are allowed.
- Scale factor. Factors smaller than 1 decrease the size of the selected objects while factors greater than 1 magnify the objects.
- By default, the selected objects will be scaled using the reference plane as reference. Optionally, the user can specify the -noLocal argument to ignore the reference plane when scaling.
We’re going to scale the height of a cone by using the scale1D command.
command> cone -c
Select center [x y z]: 0 0 0
Bottom radius [double]: 1
Height [double]: 1
Top radius [double]: 0
command> scale1D
Coordinate {x|y|z}: z
Scale factor [double]: 2
command>
Result
Figure 1. Cone scaled in the Z coordinate
