tCross
Adds a new T cross (a cross with T-shaped ends) to the geometry.
Inline mode usage:
  • tCross -h: Display a help message.
  • tCross -n name -p x y z thickness firstSegmentLength secondSegmentLength: Create a new T Cross.
Interactive mode usage:
The following steps will be needed in order to create a new T cross.
  1. Select center [x y z]: Central point of the cross.
  2. Thickness [double]: Thickness of the segments.
  3. Length of first segment [double]: Length of the first segment of each blade.
  4. Length of second segment [double]: Length of the top of the segment of each blade.
Example:
Figure 1. tCross example
