extrude
This command creates a surface by sweeping a curve along a translation vector, or by joining all of its points to a central point.
Inline mode usage
- extrude -h
- Displays the help file that summarizes the parameters for this command.
- extrude –point –s all –p <x y z>
- Extrudes all curves to a point.
- extrude –point –s name –p <x y z>
- Extrudes one curve <name> to a point.
- extrude –s all –p <x1 y1 z1> <x2 y2 z2>
- Extrudes all curves from a start point to an end point.
- extrude –s name –p <x1 y1 z1> <x2 y2 z2>
- Extrudes one curve <name> from a start point to an end point.
Interactive mode usage
Sweeping method:
- Invocation
- extrude
- Parameters
- Curves to extrude (selecting them on the screen or in the tree view).
- Start point.
- End point.
The vector that joins the start point and the end point will be considered the translation vector used for the extruding.
Point method:
- Invocation
- extrude -p
- Parameters
- The coordinates of the extrusion point.
A circle (centered at the origin, radius = 2) was created prior to the following operations.
> extrude
Select curves on screen (Press enter when done) // Select the circle
Start Point [x y z]: 0 0 0
End Point [x y z]: 0 0 3
Result
Figure 1. Result after extruding the circle
