surfaceFromEdges
Inline mode usage
- surfaceFromEdges -h
- Displays the help file that summarizes the parameters for this command.
- surfaceFromEdges –s all
- Selects all curves of the scene.
- surfaceFromEdges –s <name>
- Selects <name> curve.
Interactive mode usage
- Invocation
- surfaceFromEdges
- Parameters
- Two, three or four curves used for the creation of the coons patch. The set of selected curves must form a closed loop.
command> arcCenter [x y z]: 0 0 0Radius [double]: 1Initial angle [degrees]: 0Final angle [degrees]: 90command> arcCenter [x y z]: 0 0 0Radius [double]: 1Initial angle [degrees]: 90Final angle [degrees]: 180command> arcCenter [x y z]: 0 0 0Radius [double]: 1Initial angle [degrees]: 180Final angle [degrees]: 270command> arcCenter [x y z]: 0 0 0Radius [double]: 1Initial angle [degrees]: 270Final angle [degrees]: 360command> surfaceFromEdgesSelect a closed set of 2, 3 or 4 curves (press Enter when done): command>Result
Figure 1. Disk generated from 4 edge arcs
